Fifa 10 - Is it 09 in disguise?
7 Sep 2008
Hi all,
I'm sure a lot of you have played the demo
what did you think of it?
It feels like 09 in disguise I am struggling to find the differences.
It is the same engine so of course there will be similarities.
09 was awesome, all it needed was some tweaks, which is what they have done.
FIFA 10 is awesome.
Trust me it's not '09 in disguise mate.
It's so much more smoother and responsive and the animations are sublime, the ball is free-er and a whole host of other things.
I still have '09 - if you do stick it in and play Chelsea v Barca on it and then do that match on the FIFA 10 Demo and all shall be revealed to you. ;)
Its so so much better than 09... I oly played 09 a bit before the Fifa10 came out. After playing Fifa10 demo I went back to play 09 and its horrid in comparison.
Fifa10 is the best football game I have ever played!!
Quite similar in some areas and not so in others......10 is vastly superior though, best football game ever by a stretch.
Some siliarities (obvious ones being celebrations/commentary). Game play feels completely different.
Play the Fifa 10 demo, then try going back to '09. You'll notice.
From the demo, you can tell the tweaks they have made have a massive difference on the overall gameplay...
