Fifa 13 start up crash
16 Dec 2009
Belfast
I played the game perfectly fine a few days ago, now all of a sudden it wont start, have updated game, even re-installed it (had to downloaded it again to) still wont get past that EA logo.
I have looked over there forums there seems to be a lot of other people with this problem.
delete your online pro/game face if you have either of them (solved my issue) I had the same problem.
I deleted the ones stored in C:\Users\XXXXX\Documents\FIFA 13 i guess that is the ones you are talking about, though i didnt help :S still crashing on start up.
Yes that's where I deleted mine. Have you tried deleting the entire folder or moving to the desktop and then booting up the game ? of course you can restore the files afterwards if it doesn't work as expected.
Otherwise try repairing the install (right click on the game in origin)
none of that works either :S damn EA!!
Yeah it's a strange one I had my game crashing on start up for a couple of hours out of no where yesterday. Hopefully you figure out what the problem is.
I will, just very strange how it works fine days before then without me changing anything it doesn't work anymore, very weird.
i was right, put a crack in and it works fine :S what the hell!!
online does not seem to work :s
