Fifa 2018
Yep on Origin. If you search for Fifa 18 and hover over the image for it you'll see a button to try the demo. Not had a chance to play it yet myself though.
Well, at least you can skip FMV in "The journey" now.
Such a simple bloomin feature yet took them a year and the next version to add it.
Demo seemed really juddery on my system, almost as if GSync was turned off.
4690k
980ti
Mine felt fine on DX11. I do have to play with vsync on and I got a constant 60fps at 1440p on a gtx 980, everything on max. I tried DX12 and it was great for the most part but things like goalkicks seem to give me 30fps.
I don't know what to say other than in its current state it's bad ! It seems way to easy to score this time around ! It's way way to easy to put in a through ball & also over the top balls will always land with a fasted pace player... I don't like it but I'll probably buy it still as I do every year. Some of the new animations are cool thou like the over head side kick
The players faces are a lot better more realistic although the movement is a bit dodgy. Only tried DX12 version and it seems very smooth and slick. When Ronaldo scored he roared like a lion it was definitely not his voice and hilarious.
Hmm trying to run the demo and it's not even starting - Get up to the start screen (Play Demo/View Settings/Exit) and when I click Play, a black window shows and it just hangs :(
Did a quick search online and looks like it's a common issue for some reason...
