I found a txt file in my Fifa 07 directory that I copied and pasted from a website just before I found the actually ini files. Sorry, but I don't have a link to either the ini files or a reference for the website that provides the advice.
Probably had about 12 tabs open in 3 browsers searching for a cure to my Fifa07 problems. (I know how it feels!!!!)
This seems to happend when you have the Anti Alizing enabled, no matter how powerful PC / lappy you got.
It appears, owners of Radeon videocards seems to be the ones mostly plagued by this bug in FIFA 07.
EA is working on a patch, that should solve this problem. But until it's out. you can try this:
Go to the FIFA 07 directory. Then "Data" + "cmn" And If you are using high settings?
Then cfg_pc_h.ini
If you are using "medium settings?
Then cfg_pc_m.ini
Low?
Then cfg_pc_l.ini
Open the file with Wordpad or notes.
Now, Look for:
DISABLE_DOF = 0
IGNORE_DOF_DISABLE = 0
IGNORE_POSTFX_DISABLE = 0
DISABLE_POSTFX = 0
Change those values to 1
Save the settings.
You can also make some of the image more clear, by setting RENDER_RATE_MODE = 7, to 2
instead.
This, can also be helpful if you dont have a powerful videocard. As this lower setting will ease the strain on your card.
