FIFA RAAAGE!
Caporegime
1 Mar 2008
:(:(:mad::(:(
one of my wireless 360 controllers right stick doesn't work due to me losing to SarahBTSN (probably andy though!)
I also spat my dummy out and quit the leagues after 5 seasons because I lost one match
Fifa RAGGGGGEEE = bad
Nope, because you're now on your way to a pad conversion of putting the PS3 gubbins into a man sized Xbox360 controller! Do it!
(I wouldn't have the balls to start and I like the look of my white DS3 too much to do it :p).
Well, keep trying and if you can't get it back to the way it was, well then i suppose you have learnt your lesson...
I'm sure you could get it roughly back to how it was, with the help of a little superglue in the right places.
I was playing my mate the other day and he kept scoring the same type of goal over and over again and I could do nothing about it for some reason.
Threw my pad at the wall expecting it to explode into a thousand pieces, but obviously I'm a bit soft and it only cracked one of the grips and put a slight dent in my wall :p
