Fightstick Recommendations
15 Oct 2022
The bouncy floor
Looking for the best I can get for £100 or less. The ones that keep popping up are.
HORI Fighting Stick Mini
MAYFLASH F300 Elite
MAYFLASH F500
I don't really want to go over £100 as its my first time buying one and if I'm not keen it will just be gathering dust.
Has anyone had any experience with any I've listed? The MAYFLASH ones look more appealing due to the size but bigger might not be better as I'm a total noob when it comes to these things.
As this is to test the water, a s/h VKB Gladiator or a clone of.
It’s a great entry level stick.
What I will say is that if you decide to keep flying and wish to upgrade, do it once and do it well.
MAYFLASH F300 Elite
MAYFLASH F500
Are you handy with tools or woodwork at all?
It might be an option for you to build one instead on the cheap and use an RP2040 with GP2040CE Firmware.
I think my fightstick was about £30 in parts when I built it if you don't include the wood costs (I had some on hand).
My flatbox (hitbox style controller) was under £25 in parts.
There's lots of chinese flatboxes under £100 too, did you consider one of those over a stick?
