- 30 Sep 2006
- Midlands, UK
Happy New Year all.
Ok, to business.
I built 2 identical rigs for the kids, one works fine, the other has been a son-of-a-b*tch since day one (about this time last year).
Gigabyte GZ-1 case
Gigabyte GA-P35 DS3R mobo
2Gb PC6400 Corsair matched ram
Sapphire HD 3870 512mb
Thermaltake 500w modular psu
dvd-rw
250gb sata hdd
Logitech 5.1 speaker set
Vista HP x86
Now, the problematic pc, symptoms:
1. onboard sound had terrible interference problems, always buzzing. Fitted a x-fi pcie card which solved that problem.
2. Whilst playing cod4 the game would constantly freeze for about 10 secs every few mins. Event log showed that the ccc display driver had closed down due to an error then restarted (then consequently closed again for the next game freeze). Updating drivers didn't solve this issue (properly uninstalling and installing new ones)
3. dvd-rw drive no longer mounted, seen in the bios and by device manager but couldn't update driver for it so it won't show in 'my computer'.
So....i reformatted and reloaded vista back on, with fresh install of everything. Latest 8.12 catalyst, all updates.
Result?
1. Onboard sound doesn't buzz but will not configure correctly for 5.1. So X-Fi went back in and that sorted that, but now when the pc is booted up it emits a continuous and annoying beep until you get the windows loading progress bar then it stops.
2. 3870 still freezes on cod4, so i turned AA off (was set at x4) and that seems to have solved it.
3. dvd-rw is back and working fine.
4. tv-card has all drivers loaded but vmce just doesn't find a signal anymore to set up his tv.
Ok, so i'm wondering what component is likely to be the cause.
The mobo seems to be the common denominator here, with the onboard sound not working correctly. Could the the dvd-rw falling off the pc be caused by dodgy sata controller?
3870, could the mobo be responsible for the failing AA on that?
Could it be the hdd with bad sectors?
I've not checked the hdd yet, but i've had hdd's that have passed certified tests yet still failed.
I know bad ram can do dodgy random stuff, but i suppose equally it could be the ram slots on what i already suspect is a dodgy mobo.
All parts are about 1 year old now, so not sure which way to go with it all.
Any advice would be most appreciated.
Thanks
Ok, to business.
Gigabyte GZ-1 case
dvd-rw
250gb sata hdd
Vista HP x86
Result?
Thanks
