OK, trying to associate Crystal Report extension TRC by the following command...
assoc .trc= TpxScreen.CrystalReport
Now, when checking the association using the following...
assoc .trc
It tells me its correct but checking the 'Associate a file type or protocol with a specific program', the file extension isn't there which tells me the association failed!
WTF is going on here? I can't open the file with a program, hence using the above.
assoc .trc
