File transfer using DOS coding
19 Jan 2005
Romford, Essex
Wierd title I know, but I imagine it's the only way unless you guys can guide me to an easier solution.
I have a 2TB drive with 400 ripped DVD's on. They are ripped to MKV files and allocated their own folders also containing metadata, coverart etc.
The thing is I want to copy to another drive only the 400 MKV files to use on another media player and I don't know how.
As an oldie the only way I though was to do it from a DOS window with the *.MKV file used in within the rest of the DOS command.
Is there a simpler way or can you give me the command line that I will need to enter. Cheers.
BTW. from a leagality point of view. I own and have the DVD's.
I'm assuming (possibly unwise) that you just want to copy the files without replicating the containing folders for each one.
You could click on the root of the source drive in an Explorer window, do a search for "*.mkv" (in the search box at the top right), hit Ctrl+A to select the whole lot, and then just drag and drop them to [wherever you want to put them].
That sounds like a good idea. Why do you say unwise to just transfer the MKV's without their folders. I will still have the originals including coverart etc. on the host drive. I want to use the second drive for a Plex set up where the Plex server finds it's own metadata. Or is there a good argument for keeping each MKV within a folder. Thanks for your time BTW
No, no, I meant I was possibly unwise to make assumptions. :D
If you also want to copy the folder heirarchy, you could just do "xcopy y:\*.mkv z:\ /s" , where y is the source drive and z is the destination. :)
OK I see. Thanks for the DOS command and thank you Halfmad. I think I'll go with the *MKV within search and highlight what I want and use the Send To command. That way I can transfer say 50 a day without bogging the machine down indefinately. Thanks again guys.
