Fileserver question..
Don
21 Oct 2002
Parts Unknown
i want to use an old pc for simple fileservering and backup
i have these hard drives for it..
old 20gb spare drive
400gb sata2 drive
400gb sata2 drive
400gb sata2 drive
400gb sata2 drive
if i use the 20gb as xp drive, will it affect performance on the 400gb drives? they'll be on sata controllers
would it be worth getting a faster -say 80gb 8mb cache WD drive for windows to run on?
if the 400gb drives are shared, do files pass through the 20gb drive first? or would they go straight from the sata controller to network card
basically asking if the 20gb drive will hamper performance
i'm not asking how to configure the other drives, i can do that myself
IMO I think it might affect performance BUT because being 20GB, must be an old HD? Most likely 5400RPM? & must have been heavily used previously (i.e. wear & tear)?
Can't 'afford' a 20GB partition on one of the 400GBs?
& 1.5625 terabytes :eek: nice :)
for £83 for each drive brand new, i couldn't say no ;)
i'd rather not have the os on them, might just do some testing later with my other 200gb drive as the os holder..
While 'testing' also think of power consumption & heat :eek: & remember for file-serving the performance doesn't have to be that extreme – the network being the limiting factor!
Also, if using XP you can get away with (tried & tested) 15GB including PageFile :)
i'm using an nlited xp, so only need about 150-200mb for os, and then a bit more for pagefile, but 20gb is the smallest non-useless drive i have :)
on a gigabit network
pleased with it so far, just dont want the 20gb drive dragging it down
the drives are in this thing..
so no heat issues as they wont be getting accessed 24/7 and there's decent fan on the back, and case airflow is maximum -no cover :p
Many pc manufacturers say that no cover actually causes problems with airflow which can not only not make an improvement but infact be detrimental to the heat disappation, that said I'm not sure how true this is but running with the side of the case off is only going to increase the amount of dust that gets in the case, and dust is bad! very bad! - Just a friendly word of advice
If it's a 7200 rpm drive it should be fine, as long as you sticks wads of RAMS in. At least a GIG would be ideal.
and as long as you keep it a separate system drive to the raid array, you'll be able to replace it simply by imaging that disk onto the new one.
all i'm asking is will the files have to pass through the C drive first, or do they skip it out completly?
I wouldn't have thought that the system disk would be a factor when the files being accessed are on another disk.
I'm flattered.
I spent about 5 minutes trying to go through the process of accessing remote files in my head, just got all blury after that. :p
The OS drive will have no effect on the sharing of files on storage drives.
All that Windows needs to allow access to a storage drive is already loaded into memory - So the speed of the OS drive is completely independent of data access via the network. :)
The 20GB drive will do fine as an OS one... Once the File Server is up, it won't be rebooted often.
