Just a quick check...
Not going to be able to move my case around as one normally would for filling/etc (remotely possible if there's no other way).
Would I be right in assuming that a pipe, routed so it goes from the highest to the lowest part of the loop would work for both? Basically have it so when I'm filling I can have the liquid source I'm filling from "higher" than any part of the system (with the cap missing from the res that's otherwise at the highest point so air can escape ofc) feeding into this pipe and fill the loop from the bottom up.
When I want to drain it, drop this pipe in a bucket so it's the lowest point and... bar a bit of liquid left in blocks/etc it should happily empty the loop?
I guess there'd be a bit of a problem with air bubbles in radiators?
Standard mavity and "water finds it's own level" ideas at work... just checking I've not missed an obvious flaw in my plan.
Crude picture to maybe explain better:
https://i.imgur.com/t5O9s9O.png
