Is it generally considered not a good idea to fill all 4 memory slots on a motherboard? Are you less likely to have instability issues if you only use two out of four?
I only ask because I had a lot of problems with lock-ups on my ASUS P7P55ED-E when I first set it up with all four slots filled with identical sticks of OCZ Intel Extreme XMP 1333MHz which went away when I removed two sticks.
I've also seen other threads on here where people with memory problems are asked whether they have all 4 slots filled.
If there is a problem, is it something that is caused by insufficient voltage being shared by 4 sticks and can this generally be overcome by tweaking the voltage up a bit?
