Hi, i have got a problem that i just cant get rid of.
xvid films that are on my HDD stutter when i play them back (stutter for about 10seconds every 2mins) None of my rescources are maxed out. I have tried difrent codec packs. Uninstalled all the ones i could find (which seemed to b them all as they wouldnt play) and reinstalled. But still have the same problem, but from my other pc (same codecs) i can watch them over the network just fine.
Spec:
AMD X2 3800+
2GB Geil RAM
DFI Ultra-D Mobo
200GB Maxtor Sata
NEC DVD+-RW
Has anyone got sugestions for me to try as it is really doin my head in now. Or any programs that may help, codec cleaners, gaurnteed codecs (even if not the best quality) etc?
Thanx
EDIT: If i burn to dvd/cd then play back from there is fine, so maby its more a HDD/SATA problem, although it all shows up as healthy, any good utilitys to check this with?
Spec:
AMD X2 3800+
2GB Geil RAM
DFI Ultra-D Mobo
200GB Maxtor Sata
NEC DVD+-RW
Thanx
+1 beer 4 u.
