Ok so i got a Raynox 150 macro lens and im using this guide: http://bugmacros.com/tz3_adapter/ to fit it to my TZ5. I made an adapter out of an old plastic tube and it does work. Just about.
When i was taking pictures the stress of the Raynox 150 was too much on the plastic tube and it popped off, so im not looking for a 55mm filter adapter, like the one this guy uses here:
http://bugmacros.com/tz3_macro/imagepages/image28.html
However i have tried looking on the 'bay and haven't really found anything. I dont know what to search for cause i dont know the exact name of what im looking for. He said he used an old 55mm filter and just smashed the glass out of it, so i want to do the same thing so as to not let the 150 pop out again.
If you guys could point in the right direction of finding one for cheap, that would be a lot of help.
Thanks
Thanks
