Filter kits for 750d
12 Dec 2009
Gloucester, UK
Hi guys,
Has anyone ever used a DEMCiflex filter kits for the corsair 750d? I was looking at getting some for better dust filtering on the case and just wanted to know if their any good or a total waste of money.
How long have you had the case? I was wondering how much dust came through the top as the mesh does look pretty spaced out.
I have two 120mm and it is a very fine mesh that doesn't let any dust in they are pretty good. just a note though the magnets are pretty weak so if you planned on putting some on the bottom fan mounts (the kit doesn't include them for the bottom) they will fall off I got around this by putting them inside the case on top of the fan.
