Hi all.
I'm after some filters, but the two lens i have and the next one i want to buy are all different thread sizes.
sigma 10-20 is 77mm
kit is 52mm
and nikon 18-200 VR is 72mm
I have UV filters on my lenses, and 52mm ND4, ND8 and R72 filters. But i want IR, and also ND and ND grad filters i can use on the other lenses.
I was looking at getting the bits for the Cokin P filter system. Good idea, what else is there out there? I know i might have a few issues with a CPL doing this. But otherwise it should be fine on all sized lenses, yeah?
Had a quick look around, and found some holders for the filters that are very cheap. Are they generally that cheap, or are the cheap ones naff and will let light in around the filter?
sigma 10-20 is 77mm
kit is 52mm
