I have just bought an Antec 300 Gaming case and want to add some filters to the 140mm top fans and 120mm rear fan.
Both fans fit under a raised mesh portion of the top and rear panels respectively so fitting a flush fan is out of the question. Have had a look at magnetic filters but again the clearance seems to suggest they too are made to fit completely flat panels rather than ones with a raised mesh area over the fan.
Any found or can think of a suitable fan housing / filter combination?
Thanks
Ric
Thanks
Ric
