Final build check!!!
Man of Honour
21 Nov 2004
I am ordering this within the next two days!!!! Complete list:
Intel Core 2 Quad Q9550
Tuniq Tower 120...not in stock :( and Noctua NF-P12 120mm Silent Case Fan
Arctic Cooling MX-2 Thermal Compound
Asus Rampage Formula DDR2
2x OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel Platinum Series DDR2
Sapphire 4870 X2 - not in stock, so may have to get elsewhere :(
Samsung SpinPoint F1 1TB
Dell Ultrasharp 2408WFP 24"
Logitech Z-5500 THX Certified 5.1 Speaker System
Asus Xonar D2X 7.1 PCI-Express Sound Card
Coolermaster RC-1100 Cosmos S "Sport" Silent Full Tower Case
Coolermaster Real Power 850w Modular Power Supply
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive
Logitech Cordless Desktop MX 5500 Revolution
Microsoft Windows Vista Home Premium SP1 64-Bit
Akasa AK-PAX-2 PaxMate Plus Acoustic Absorption Mat
Akasa 20/24-Pin 30cm PSU Extension Cable
Akasa AK-TK-01 Cable Tidy Kit
Akasa AK-TK-02 Cable Tidy Kit
Budget about £2300. This comes to about £2250 :D. Ok so it was orginally £2000, but I changed my mind :)
What do you guys think?
You could change the CPU cooler to the Noctua NH-U12P and both save a little bit of cash and it is in stock.
Any particular reason you want the Sapphire 4870 X2? The HIS version ought to perform just as well albeit with a 1 year warranty instead of 2 years.
I would have said Sapphire, HIS and Powercolour were all pretty established brands on ATI cards. Just save yourself 35 notes and get the HIS one in my opinion :)
Gaming mostly (and movies quite a lot)....Spore at first, then Crysis, Mass Effect and eventually Fallout 3 (in that order :)). Also run CPU intensive scripts for Bioinformatics type stuff, so will be useful for that too.
Also planning to overclock the hell out of it!
