Final Build for Gaming
6 Nov 2011
Hey,
I would like to Thank everyone here on ocUK for all the support I've received in that past few days / weeks. You guys are amazing, I will definitely stick for longer!
So I decided to build a new pc for gaming with budget of £600 + I can put up to £100 extra if needed (will buy gpu separately when 1070 is released)
Here is what I decided to buy (possible changes):
My basket at Overclockers UK:
Total: £597.63
(includes shipping: £11.70)
is there anything you guys would change??
Thanks once again
Hi
Fractal Design R5 is a silence orientated case. It has sound damping already installed.
SuperFlower Leadex is a much better psu (If you don't mind the White LED connectors which you can see in one of the listing pics)
Alpenfohn Matterhorn is a very good budget cooler. You don't really need extra thermal paste as the cooler will have some.
Total: £555.00
(includes shipping: £14.10)
Hi
Thanks for your feedback :)
I will stick with my case as it will be something I will see everyday and I really like the look of the Phantom.
SuperFlower looks good :)
Im not really looking for budget cooler, did that mistake once in the past and it didn't turn out well :P + from what I've heard be quiet! is top tier these days
Case choice is personal so fair enough on that.
Yup SuperFlower are one of the top oem's along with the likes of Seasonic and Delta.
It is only budget in price. The BeQuiet coolers are very nice (I have a Dark Rock 2) but they are very fiddly to install.
As long as the cooler fits then it looks good. Might be worth asking when you order.
looking good.
Ive looked at the same motherboard bundle you have bought.
If it wasnt for me upgrading to an i5 4690k last year I think I would go for that.
have you decided which GPU youre going for?
