Firstly I'd like to thank you all for the helpful advice in the other thread. I've decided to go ahead with the purchase however I have a final few questions.
I'm planning on buying the Canon EOS 550D with the 18-55mm kit Lens and also the Canon EF 50mm f1.8 MK2 lens.
Questions
1) I gather you can produce almost film-like results with this camera although there are constraints which have to be worked around. Some of the reviews mention that when shooting fast pace action (i.e. someone running/jumping) there is sometimes a distortion effect. Is this true?
2) I'll be using it with a tripod most of the time. Is the camera truly useless as a handheld camera? If I went skiing and ski'd behind a mate (having already set the camera in focus) would the footage be horrendous or just like it would be with a normal HD camcorder?
3) Anything else I should know if I'm using this to shoot short films. I realise the microphone is pretty awful and mono but we rarely use sound from the actual shoots anyway. Nearly the entire sound track is added in the editing phase and if we shoot dialogue we record it using separate device and sync in editing.
4) I'm going to look into getting a copy of Adobe Premiere Pro or something of that ilk. Can the footage be dragged straight off an SD card and into the video editing applications or does it need to be converted? I'm assuming my MBP I.Core 2 Duo 2.66Ghz will be able to handle everything?
Many thanks again for the advice,
Cheers
Questions
Cheers
