Final check for my spec
11 Aug 2010
Hi All,
Please check my spec for me - I'm about to order. Please feel free to offer alternatives (especially the case which is out of stock at the moment). The budget is £760 and the spec below comes to £756.62.
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card - £173.89
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail - £159.99
Asus M4A87TD/USB3 AMD 870 (Socket AM3) DDR3 Motherboard - £86.99
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) - £79.99
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) - £76.36
Antec Solo Quiet Mini Tower Case - Black/Silver - £74.99
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM (ST31000528AS) - £49.34
AcoustiFan DustProof Quiet 120mm Fan - 3 pin - £18.79
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM - £15.99
Xilence XPF92R Red Wing 92mm Quiet Fan - £5.60
Thanks,
PM
What are you going to be doing to need a hexa core?? Gaming its pointless so unless your rendering cad, video editing or somthihing like that just get a 955 x4 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM&groupid=701&catid=6&subcat=1328 £111.61 this week).
Case (im assuming your after quiet ones)
Antec Sonata Elite Case £70
http://www.overclockers.co.uk/showproduct.php?prodid=CA-109-AN&groupid=701&catid=7&subcat=160
Fractal Design Define R3 Midi Tower Case - Black Pearl £90
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-FD&groupid=701&catid=7&subcat=1556
It would also be worth getting an aftermarket cooler as the quiet designed cases tend to have less airflow and the dampening material can also retain heat.
Arctic Cooling Freezer Xtreme Rev.2 £28
http://www.overclockers.co.uk/showproduct.php?prodid=HS-038-AR&groupid=701&catid=57&subcat=1395
Dont forget your thermal compound
Arctic Cooling MX-2 Thermal Compound £5
http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-AR&groupid=701&catid=57&subcat=27
on the contrary I'm a supporter of getting a hexcore if you will be keeping the CPU a while, that way as games are gtting more and more multithreaded you will benefit
