Since the 290s haven't sold - and tbh their performance is absolutely fine - I am going to WC them in the next week
Final check please
Questions/notes:
1. I wish to use a multi-GPU connector. Series or parallel? Is the one selected right? My Mobo is three slots wide (60.9mm). But this one is CSQ
2. The Rev2.0 block is the updated version for the MSI Gaming OC 290 - hopefully? Checked Cooling Configurator
3. Nickel for GPU and CPU block - ideal? Anything else I need to add like biocide or any other stuff?
4. I have drawn pics to count the type and # of connectors needed. I do already have some I can reuse
5. The plan is to mount the pump at the rear in the usual place in a 540. PUMP/RES -> CPU BLOCK -> TOP 240 -> GPUS -> BOTTOM 360 -> PUMP/RES
6. Front 360 will be intake. Top 240 will be exhaust. Rear 120 will be exhaust also
YOUR BASKET
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
2 x EK Water Blocks EK-FC R9-290(X) - Nickel Rev.2.0 £87.95 (£175.90)
1 x EK Water Blocks EK-Supremacy - Full Nickel £64.99
1 x EK-FC Bridge DUAL Serial 3-Slot CSQ £16.99
1 x EK-FC Bridge DUAL Parallel 3-Slot CSQ £14.99
1 x Mayhems Pastel - Red Coolant 1L £14.99
1 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Red £8.69
3 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Red £8.69 (£26.07)
3 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length] £2.99 (£8.97)
Total : £449.16 (includes shipping : £8.00).
Final check please
Questions/notes:
YOUR BASKET
