Final check
4 Dec 2005
Merthyr Tydfil
Sorry to be a bug!
OCZ StealthXStream 500w Silent ATX2 Power Supply (£43.46)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) £17.61)
Leadtek GeForce 8800 GT ZL OC 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (£140.99)
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail
(£152.74)
Thats the final spec for my upgrade,
its a hp6325, all items checked for compatibility, does the psu supply enough juice.
system has 3gb of 667 ddr2 and a seagate 7200 500gb sata, dvdrw sata
I know the corsair 520 is highly recommened but cant afford any more than that really!
All ok?
Lee
The PSU should be fine, OCZ make decent enough PSUs and your system isn't too demanding as is specified there.
I'd suggest going for faster Ram when you can afford it since that Ram will only run the CPU at stock speeds but might have issues about too much further if it is just average generic stuff.
