Hey guys new to the forum, and posted up a budget build the other day, went over budget but this is the result after a very brilliant effort and help from a lot of guys and one poster in particular
Just thought i'd post a final spec to see if any of you have any advice on anything at all?
Questions I have are:
How overclockable is the motherboard/processor? Not planning to go stupid, but 4ghz would be nice.
The guys told me 500w should be fine, but just a query, is it at the peak so to say? If that makes any sense...
Finally, the GPU is a "black edition" which the guys said basically means it has been overclocked a little (if i remember correctly) however i found a better deal but it doesnt state black edition, and I just wanted to check if the performance would be exactly the same or the black edition would be faster?
PC Spec
CPU:156.18 - Intel CPU Core i5 2500K Unlocked Sandy Bridge Quad Core Processor OEM.
GPU:£131.62 - XFX HD 6780 Black Ed. +Shogun 2 game.
MOBO:68.82 - Gigabyte GA-Z68A-D3 Motherboard.
PSU:£43.78 - Corsair Builder Series CMPSU-500CXUK 500W Power Supply (PSU)
Ram:£37.00 - G-Skill 4GB (2x2GB) DDR3 1600Mhz RipjawsX Memory Module CL9 (9-9-9-24) 1.5V
HDD:£29.98 - 500GB Samsung HD502HJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 16MB Cache, 8.9ms, NCQ.
Case:£28.71 - Casecom 6788 Black Mid Tower Case.
Cooling:£15.99 - Coolermaster Hyper 212 plus.
DVD Drive:£14.99 - Sony AD-5260S-0B 24x DVD±R, 12xDVD±DL, DVD+RW x8/-RWx6 SATA, Black, OEM.
_________________
Product+Delivery:£538.24
Overclockers has been a great help so far, one poster in particular seems very dedicated!
PC Spec
_________________
