Hi,
Before i begin i know this is partly my fault for not checking the requirements of the software but i have a problem with installing Final Cut Studio 2.
Basically i bought the software off competitor and it arrived today, i have a macbook pro with stock harddrive (140GB) now i have used a fair bit of space through music and other apps, anyway i have 30GB left however it seems i don't have enough space to install final cut studio.
when i try to install, the installer insists on trying to install Soundtrack pro which is 21.1GB?? (See Below) do i need this, really?
Click for full size - Uploaded with plasq's Skitch
If there is no way to disable Soundtrack Pro should i just buy a bigger harddrive?
Thanks in advance.
Thanks in advance.
I thought Logic 8 was huge!
