Ok well thanks to all for the loads of help when i wanted a spec last time here a few last questions
will this memory be ok ?
1Gb Corsair Value Select PC3200 DDR (400) , 184 pin DDR Non-ECC Unbuffered , CAS3Lifetime Warranty + Akasa AK171 Copper Heat Sink/Spreade - £61.69 vat inc
AMD Athlon 64 Socket 939 Dual Core 4200+ 1MB 'Manchester' Retail
now is there much diuffrence to these cards
256Mb GECUBE ATI PCI-E X1800XL GDDR3 256Bit Dual DVI AViVo
256Mb PowerColor PCI-E X1800XL DDR3 256bit TVout Dual DVI AVIVO
256MB ATI All In Wonder X1800XL PCI-E DVBT + Analogue Hybrid Remote
or shd i get a 512MB PowerColor X1800XT PCI-E DVI/VIVO for £60 more
any advice would be good
looking at these board s
Asus A8R-MVP S939 ATI 200 Crossfire DDR400 SATAII Raid USB2 GbE Lan 6Ch Audio
Asus A8R32-MVP Deluxe S939 - RD580 2x PCI-E XFIRE GbE SATAII Raid - 8ch Sound
or is there a better allternative
CPU amd Dual core 4200+
i think thats all the questions cheers Liam
