OK - after much deliberation and lots of learning, I think I may have finalised a spec and am looking to order some, if not all, of the bits today / tomorrow to take advantage of Offer of The Week and 666.
Main uses:
Standard Office / Browsing
Photoshop CS2 (will probably upgrade to CS4)
Some video
Some gaming by 10yo son (but this is not to cause significant change to spec!)
Vista 64 bit
Spec, pretty much decided, although GPU still under discussion in the Graphics Forum
Does this look balanced, sensible etc etc?
Do I need anything else? Cables, ties, extra fans, etc etc? (I've got a screw driver
All / any thoughts appreciated:
Now edited to take account of fobose's suggestions
*** UPDATE *** My final ordered and delivered spec is set out at the bottom of this thread - in case anyone is even vaguely interested!!
Main uses:
Some video
Vista 64 bit
)All / any thoughts appreciated:
Also, to the OP: You might want to get some intake fans to your case as they dont come with any; something cheap with good air flow and low db rating like this would be good I think:
