Final Reveal -1/48 Tamiya supermarine Spitfire MK1
5 Feb 2006
The Supermarine Spitfire is a British single-seat fighter aircraft that was used by the Royal Air Force and other Allied countries before, during, and after World War II. Many variants of the Spitfire were built, using several wing configurations, and it was produced in greater numbers than any other British aircraft.[citation needed] It was also the only British fighter produced continuously throughout the war. The Spitfire continues to be popular among enthusiasts; nearly 60 remain airworthy, and many more are static exhibits in aviation museums throughout the world.
The Spitfire was designed as a short-range, high-performance interceptor aircraft by R. J. Mitchell, chief designer at Supermarine Aviation Works, which operated as a subsidiary of Vickers-Armstrong from 1928. Mitchell pushed the Spitfire's distinctive elliptical wing with cutting-edge sunken rivets (designed by Beverley Shenstone) to have the thinnest possible cross-section, helping give the aircraft a higher top speed than several contemporary fighters, including the Hawker Hurricane. Mitchell continued to refine the design until his death in 1937, whereupon his colleague Joseph Smith took over as chief designer, overseeing the Spitfire's development throughout its multitude of variants.
During the Battle of Britain, from July to October 1940, the public perceived the Spitfire to be the main RAF fighter, though the more numerous Hurricane shouldered a greater proportion of the burden against Nazi Germany's air force, the Luftwaffe. However, Spitfire units had a lower attrition rate and a higher victory-to-loss ratio than those flying Hurricanes because of the Spitfire's higher performance. During the battle, Spitfires were generally tasked with engaging Luftwaffe fighters—mainly Messerschmitt Bf 109E-series aircraft, which were a close match for them.
Build Thread: https://florymodels.websitetoolbox....ermarine-spitfire-mk1-10679998?pid=1317580510
  • Kit Manufacture: Tamiya
  • Kit Number: 61119
  • Scale : 1/48
  • Type: Supermarine Spitfire
  • Extras: None
  • Paints: Mr surfacer 1500 white primer, MRP NATO Black and various Tamiya.
  • Weathering: Flory Dark Dirt Wash, various abteilung 502 oils.
Camo markings are spot on. Going to assume that you used masks for them?
Highlights for me are the exhaust and gun port weathering.
