Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN) (£117.49 Including VAT at 17.5%)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI) (£105.74 Including VAT at 17.5%)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL) (£199.74 Including VAT at 17.5%)
Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) (CA-054-LL) (£57.56 Including VAT at 17.5%)
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR) (£17.61 Including VAT at 17.5%)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (£88.11 Including VAT at 17.5%)
EVGA GeForce 7900 GS 256MB GDDR3 HDTV/Dual DVI (PCI-Express) (£138.64 Including VAT at 17.5%)
Total = £721 (Including VAT at 17.5%)
Plan is:
Within 90 days STEP UP -
to
EVGA e-GeForce 8800 GTX w/ ACS3
Questions:
Will this spec allow me to play battlefield 2142 at 1680*1050 in the meanwhile before i STEP UP to the 8800gtx?
Everything should be ok with simply replacing the old graphics card with new? ie. no power/compatibility issues
Many Thanks
1mm3
Plan is:
to
Questions:
Many Thanks
1mm3
