Final spec check before I order
18 Aug 2006
ChCh, NZ
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI) £108.09
Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) £170.36
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) £230.29
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) £164.49
Seasonic M12 Modular 600W Silent ATX2.0 Power Supply £117.49
Asus DRW-1608P3S 16x16 DVD±RW Dual Layer ReWriter (Black) £24.66
Thermaltake VB1000BWS Soprano SuperMidi Tower - Black £50.47
Scythe Infinity Heatpipe CPU Cooler (Socket 478, 775, AM2, 754, 939, 940) £38.76
Total: (including VAT) £904.61
I can push for £1000 so I'm still undecided about the graphics card.
PS.
Have a HD and x-fi soundcard.
I don't know what monitor you have so I won't really comment too much on the graphics card other than to say if you have a monitor capable of 1600x1200 or more then it might be worth considering a card with 512mb Ram, otherwise that one is fine.
I would however suggest three changes - the motherboard for an Asus P5W DH Deluxe as it is based on the 975 chipset which is supposed to work better with the 6600 and above chips for overclocking. Secondly I'd go for PC6400 Ram as that ought to match up better with a 6600 and finally the least important change is to go for an NEC or Pioneer DVDRW drive instead of the Asus, it might be personal preference but I think they are better drives overall. :)
Can the Asus P5W be upgraded to run the Quad CPU when they ship? That the only reason I picked the Gigabyte since it can be upgraded. Oh, and I have a 19inch monitor that can display 1600x1200 so I might upgrade to the 512 card
Sorry I don't know if the Asus will be able to use the Quad-core CPUs, I suspect that there will be a bios flash but probably better if you check up on it rather than going by what I'm guessing here. :)
