Final spec check please ?
17 Oct 2005
HI all, I would like to hear your thoughts on this little lot!
AMD Athlon 64 X2 3800 - OEM
Asus A8R32-MVP Deluxe Crossfire
Mushkin 2GB DDR XP4000 Extreme Performance Dual Channel Kit (2x1GB) 3-4-3-8
2 X Hitachi Deskstar T7K250 NCQ 160GB SATA-II 8MB Cache - OEM
Thermaltake Big Typhoon 4 in 1 Heatpipe (Socket 939/754/775/478) CPU Cooler
Lian-Li PC-7 PLUS Silver Aluminium Midi-Tower Case (No PSU)
PowerColor ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail
Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU
Will be OCing - hopefully to at least 2.5ghz but needs to be 100% stable.
Machine used 90% for gaming with a little encoding and the like.
I am picking items up tomorrow(Sat 18th) and will be checking case has 2x120mm fans.Will also check steppings on CPU but am unsure exactly what is best for OEM model.(cry fo help)
This is my first build and I am at the top of my budget but would like any input/advice you might have as I have decided the spec by trudging these boards.
I just hope I have not made any stupid mistkes!
Thanks.
Looks very good.
I assume you mean X2 3800+ for CPU. And that should overclock very nice with that CPU Cooler.
Mushkin ram as you you know is great stuff.
Asus A8R32-MVP Deluxe Crossfire - a great mobo.
Case & PSU are top stuff.
ATI Radeon X1900 XT 512MB - cant go past that card for value for money!
