Final Spec check
27 Nov 2004
After much consideration I have decided to go with the following spec.
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788) £59.99
Sony Floppy Drive - Black £4.99
Pioneer DVR-212D 18x18 DVD±RW Serial ATA Dual Layer ReWriter - (Black) OEM £16.99
Seagate Barracuda 7200.10 250GB ATA-100 16MB Cache - OEM (ST3250620A) £38.99
Lian-Li PC-7 PLUS II Aluminium Midi-Tower Case - Black £49.99
Tuniq Tower 120-LFB CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
OCZ 4GB (2 x 2GB) PC2-5400C5 Dual Channel Vista Upgrade Gold Series DDR2 (OCZ2VU6674GK) £59.99
BFG GeForce 8800 GT OC2 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £164.99
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £57.99
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard £69.99
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
Total £810
I will be OCing it, so will it all be ok to OC, nothing to hold it back?
Also is the PSU ok?
Thanks
All looks good, the parts are compatible and the Corsair is easily capable for that system. :)
//edit although I'd change the hard drive to a SATA model, you only have one IDE port on that motherboard.
