After the advice from other threads, i have taken onboard what people have said and would like you to double check it will all go together without any problems!
Thanks again heres the spec
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail
Sony NEC Optiarc DDU1615S 16x SATA DVD-ROM (Black) - OEM
Akasa AK-ZEN-01-BK Zen Black Case - No PSU
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Gigabyte GA-P35C-DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
PNY GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Western Digital RAID Edition 320GB SATA-II 16MB Cache - OEM (WD3200YS)
Antec NeoHE 550W Modular ATX2.0 PSU
I was going to originall get the Corsair 520 but its out of stock and the Antec NeoHE 550w has some good reviews so i went for that, will it be fine? and also the motherboard has DDR2+DDr3 capability so that means there are two DDR2 slots and 2 DDR3 slots or can i put the ram in either?
Thanks!
Thanks!
