Final Spec Check
26 Jul 2008
Getting ready to order and just wanted some advice on the following.
I don't do much gaming, just want to have several apps running at once.
What improvements should I make?
Is everything compatible?
Have I forgotten anything?
Is the case worth it?
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Socket LGA1366)
Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK)
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
Western Digital Caviar Black 500GB SATA-II 32MB Cache
Western Digital Caviar Black 1TB SATA-II 32MB Cache
XFX ATI Radeon HD 4890 XT 1024MB GDDR5 PCI-Express Graphics Card
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive
Antec P183 Super Midi Tower Case - Gun Metal Black (No PSU)
Thanks.
P.S: If you want a fast hdd for OS, which i think is the reason you got a raptor, i'd save money in other areas, and get a small ssd.
if not, just partition your 1TB hdd, as it's fast enough on it's own.
