Final spec check
Suspended
15 Dec 2009
Bristol
Recently I've been getting some advice and information regarding a new build I was planning. I won't be ordering this until tuesday, but now is a good as time as any to finalize my spec.
So without further ado:
http://i.imgur.com/zdqhO.png
(Linked instead of posted as it's a bit wide.)
Any changes I could make? I am willing to spend a little extra if it makes a noticeable performance increase. Max budget is £750
Also, am I right in thinking that the DVI to HDMI cable will work with that card, or should I just get a DVI to DVI? I'm currently using a VGA cable, though my monitor has a DVI socket too.
Never ever trust what OCuk write as a description, they even claim theres only 3Xsata2 connectors which isnt right, there are 4 of them.
Always check the manufacturer website for the correct info.
i wouldnt change a thing about that now.
I have a habit of being too trusting of things on the internet. It's my biggest flaw, though some may argue otherwise.
Cheers Stu. I think that's two beers I owe you now.
