Final Spec - please check guys!
2 Aug 2004
London, UK.
Can you check over this final spec guys, and just make sure everything is compatible and will fit in the case. Much appreciated, can't wait to order this. Thanks.
as mentioned if the o/s isnt 64 bit then you'll only get 3/3.5gb usable out of you're 4gb.
can drop the gfx card to the oc, over the oc2, unless its on special offer.
maybe change the hard drives to the western digital 500 aaks versions.
abit ip35-pro motherboard may be worth a look.
nice setup, similar to a fair few others and not seen any mention of issues.
