Hi all,
Right looks like I'm going to go with the following spec for my Dads PC. What I need to know is will the ASUS P5K Pro be able to support the E8200 Wolfdale CPU I've chosen right out of the box? Or will I have to update the bios first?
If I do have to do that, what’s the best way to do it because I don't have a spare Intel cpu so it would need to be done from the moment I turn it on (with the E8200 in) for the first time. I've heard stories of it booting up and asking to be updated but then because people didn’t have it with them prior to it they've turned the system off to find it wont boot up again - so you kind of get one chance to do it. The last update to support the 45mn cpus was 18th Jan so will it be likely that I get a board with this already on?
Am I worrying for nothing? Or should I have it all ready just in case it needs the update? What’s the best way to do it seeing as I wont have a FDD. I've got a mem stick.
Help?
Spec:
MOTHERBOARD - Asus P5K Pro Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £72.99 (£85.76)
CPU - Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB) - Retail £99.99 (£117.49)
RAM- Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB) £29.99 (£35.24)
GPU - PowerColor ATI Radeon HD 2400 PRO SCS3 SILENT 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £24.99 (£29.36)
HDD - Western Digital Caviar SE16 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) £37.99 (£44.64)
OPTICAL DRIVE - Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £14.99 (£17.61)
CASE - Antec Solo Quiet Mini Tower Case - No PSU £51.99 (£61.09)
PSU - Akasa Ultra Quiet 500W Paxpower Active PFC ATX2.2 PSU - Black Nickel £44.99 (£52.86)
OS - Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01991) £47.99 (£56.39)
THERMAL COMPOUND - Arctic Ceramique Thermal Compound (2.5g) £1.99 (£2.34)
Total: £502.78
Apart from everything else does the spec look like it will work with one another? Sorry for posting so many times.
Thanks all,
RoEy
Help?
Spec:
Total: £502.78
Thanks all,
RoEy
