Final spec + watercooling check
25 Jun 2008
Bonnie Scotland...and sometimes Denmark!
Right, just having a final check of this spec before I hit the order button on the remaining parts. Any comments would be great :)
Core System
  • Asus Rampage Extreme Intel X48
  • (2x) GeIL 2GB DDR3 PC3-12800C7 1600MHz Black Dragon
  • (2x) HIS ATi 4870X2 2gb
  • 300gb WD Velociraptor
  • (2x) Samsung SpinPoint F1 1tb
  • Thermaltake Toughpower 1000w
  • Dell Ultrasharp 3008WFP
Watercooling
  • EK Supreme Clear Top CPU Block
  • (2x) Laing DDC 1-T Pro 10W 12V DC Pump
  • (2x) Thermochill PA120.3 Radiator
  • (2x) XSPC Dual Bay Reservoir- UV Blue
Havent listed all the blah things like tubing and fan grills for obvious reasons :) CPU and case have been taken care of already (9770 and MM Ascension) :D Heard the Rampage board is a bit picky about RAM which is a concern, and that really just leaves GPU blocks.
Regards
I suggest replacing the CPU and get an AMD 3000+ Barton instead, and perhaps replace the GFX cards with 2x radeon 9800s? XTs if you want to spend a little bit
