Final spec!
27 Sep 2012
Right, I am aiming to buy at the weekend so I finally have a spec together.
I would appreciate any advice on last minute adjustments or whether anything will not work with another component!
My build:
YOUR BASKET
1 x Iiyama ProLite G2773HS 120Hz 27" Widescreen LED 1MS Monitor - Black £319.99
1 x MSI GeForce GTX 670 OC Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card (N670GTX PE 2GD5/OC) £311.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
1 x CM Storm Stryker Full Tower Gaming Case - White £129.98
1 x Gigabyte Z77X-UD3H Intel Z77 (Socket 1155) DDR3 Motherboard £129.98
1 x Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK) £94.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £85.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £69.98
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £69.98
1 x Phanteks PH-TC14PE CPU Cooler - Blue (Socket LGA 2011/1155/1156/1366/775/AMD AM2/2+/AM3) £66.98
1 x Gigabyte Force K3 Gaming Keyboard £29.99
1 x Logitech G300 Gaming Mouse (910-002489) £29.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £26.99
1 x Samsung SH-S222BB/RSMS 22x DVD±RW SATA ReWriter (Black/Silver/Biege) - Retail £19.99
Total : £1,595.95 (includes shipping : £20.10).
Uses will be gaming with dual monitor (second monitor is an old Dell 22" - to be upgraded at a later date along with a second graphics card).
The M4 has been superseded by better drives now.
Also max IOPS (input/output operations per second) also makes a crucial difference in SSD performance, the Samsung does this very well.
Ok, thanks Stulid. I will go with the Samsung then!
Edit - I have just moved into a new house and my powerline adaptors have decided to pack in. Is it best to just get a good USB adapator?
I don't think so Stulid and I suspect it is the wiring in the house rather than the adaptors as they were fine before the move.
triggerthat - I have no idea but reviews seem to be good. I was torn between the 27" and a 24" with better res.
Right I have updated my build to include a sound card and headphones (old couple next door so cant go blaring out surround sound!).
YOUR BASKET
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £94.99
1 x Samsung 128GB SSD 830 Notebook/Apple Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128N/EU) £85.99
1 x Creative Draco HS-850 Gaming Headset £33.98
1 x Asus Xonar DGX 5.1 PCI-Express Sound Card with built in Headphone Amp £26.99
Total : £1,656.92 (includes shipping : £20.10).
Would people recommend I go for a 24" screen with higher res, such as:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-DE&groupid=17&catid=510&subcat=
The resolutions are the same. But the Dell has an aspect ration of 16:10, where as most monitors are 16:9.
Monitors with higher resolutions are generally more expensive.
