Final Spec
3 Apr 2013
Northern Ireland
Hi I have decided to go with the following specs below. It will be used for Gaming also I will be adding another 760 in there in the furture. Not to sure about the PSU though and what about the motherboard aswell? I have a budget of about £800 but I can go other a bit but I would prefer to keep it as low as possible.
YOUR BASKET
1 x OcUK GeForce GTX 760 2048MB GDDR5 PCI-Express Graphics Card £179.99
1 x Intel Core i5-4430 3.00GHz (Haswell) Socket LGA1150 Processor - Retail £137.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £113.99
1 x Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK) £109.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £71.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £65.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £54.95
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £49.99
1 x TP-Link 300Mbps Wireless N PCI Express Adapter (TL-WN881ND) £16.99
1 x Gigabyte KM6150 Keyboard and Mouse Set £9.98
Total : £824.45 (includes shipping : £10.50).
Also do you think this will last for a few years when I add the second GPU?
That's better.
Seasonic are considered one of the best PSU manufacturers.
Spec still needs a "K" cpu for overclocking :(
You could drop the os as there is a 3 month trial for windows 8, use the money saved on that for the 4670k then in 3 months time buy the full os?
Would say get the £215 MSI 7970 but that would require you to order tonight as the offer ends tomorrow morning.
