final thoughts before i order
8 Apr 2007
going to order this set up any advice if i should change anything before i do so its going to be for games and online and played on a 19" tft and cost just under 600 quid
Gigabyte GA P35-DS3P, iP35 Express, S 775, PCI-E x16,
Intel Core 2 Duo E4600, S775, 2.4 GHz, 800MHz FSB, 2MB Cache, Retail
Coolermaster CM-690 Dominator Black Midi Tower Case with Mesh Front Panel w/o PSU
2GB (2x1GB) Corsair TwinX XMS2 DHX, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5
Arctic Cooling Freezer 7 Pro - P4 up to 4.4GHz - S775 Dual Core / Core2Duo Ready
Optiarc/NEC AD-7173A-0S 18xDVD±R, 8xDVD±DL, DVD+RWx8/-RW x6, DVD-RAM x12, IDE, Silver,OEM,Labelflash
480W XClio-SCF aPFC Super Silent SLi (21Db) 12cm Fan 8/20/24 ATX2/2.01 12vEPS + SATA+PCI-E Hi-End
320 Gb Western Digital WD3200AAKS Caviar SE16, SATA300, 7200 rpm, 16MB Cache, 8.9 ms
512MB BFG Technology 8800GT OC, PCI-E 2.0 (x16), 1800MHz,
looks fine.
being as you're getting a cpu cooler maybe see if you can get the processor as oem , may save you some money.
