final water cooling check
22 Jul 2006
Ok so overclockers are running out of stock on a fair amount of products i was going to buy, going to be ordering in the next few days and these are the products they have in stock.
How would this cool the e6300 and possibly eventually the gfx card i am also getting at the same time in the future? Anything you would change that is IM STOCK at overclockers?
Thanks
With respect I do not rate the rad, cpu block or pump. The rad will not give you the flowrate you will need to cool an overclocked chip and gpu, the pump is not powerful enough and your block is near bottom of the pile for cooling efficiency. Would not advise to buy unless you just want a quiet PC, in which case its all fine.
dude it's fine. For the money you can't have everything and where you have spent the money is the rad. Drop the AS5 for some MX-2 and your good.
bought :D
a good start into water cooling imo, will be only cpu then eventually gpu, so if it proves to be a bit carp fro cooling both easily upgrade pump / res.
thanks for input guys.
