Finalised Speck Check :D
13 Nov 2012
Welling
Hello, i have made couple of speck checks but this is the final one before i order these parts, I will be using an Alphacool xt45 240mm in an Air 540. I havent included any 45 degree fittings as i dont think i need them. I have included an image of my plan.
YOUR BASKET
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £79.99
1 x EK Water Blocks EK-DCP 2.2 X-RES (incl. pump) £63.95
1 x EK Water Blocks EK-Supremacy Clean CSQ - Nickel £52.99
1 x Mayhems Pastel - Ice White Coolant 1L £14.99
1 x Bitspower G 1/4" Matte Black Rotary 90 Degree IG 1/4" Adapter £10.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - White £8.99
4 x Bitspower Premium G1/4" Black Matte High Flow 7/16" ID (5/8" OD) Compression Fitting £6.98 (£27.92)
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - White £6.98 (£13.96)
1 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear £5.99
1 x BitFenix Alchemy 8pin EPS extension 45cm - White £5.99
1 x Akasa AK-TC TIM Clean CPU & Heatsink Cleaner £5.99
1 x Bitspower IG1/4" Extender - Black Matte Finish £2.99
2 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£5.98)
1 x XSPC PSU Bridging Connector (24 Pin) £1.3
Total : £313.43 (includes shipping : £9.50).
