Hi there
So maybe your wondering its just a cable, surely not that important, wow lets just say people have been waiting for these things for a long time and now they are here and these new ones are so much cheaper than the other.
Sapphire Active DP to SL-DVI-D Adapter Cable @ £23.49 inc VAT
SAPPHIRE’s new DP to Single Link DVI adapter is an active solution in a short pigtail format with DP plug to DVI female connector that allows users to connect DVI monitors with resolutions of up to 1920 x 1200.
Designed to be used with the DisplayPort output on HD 5000 series cards, the SAPPHIRE Active DisplayPort to DVI Adapter both changes the connector form factor and corrects the electrical signal to be used with a third DVI monitor.
Features:-
- Support HDTV resolutions up to 1080p and 1920x1200 computers resolution.
- Extended colors up to 8-bits per components for millions of colors output.
- Plug-and-Play. No Software Installation required.
- Eyefinity Support!
Only £23.49 inc VAT.
ORDER NOW
Basically this cable lets you run eye-infinity across 3 DVI monitors, so no need for a DisplayPort monitor in the setup any more.
Features:-
ORDER NOW
