- 4 Jan 2013
- kent
YOUR BASKET
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £77.99
1 x SanDisk Ultra Plus 128GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDHP-128G-G25) £49.99
1 x Antec ISK 600 Small Form Factor ITX Chassis £44.99
1 x SuperFlower Amazon 300W "80 Plus Bronze" Power Supply £37.99
1 x AMD Athlon 5150 1.60GHz Quad Core Processor - Retail (Socket AM1) £35.99
1 x Asus AM1I-A AMD AM1 (Socket FS1b) DDR3 Mini ITX Motherboard £26.99
1 x Asus HD 5450 SILENT 1024MB GDDR3 PCI-Express Low Profile Graphics Card £25.99
2 x TeamGroup Elite 2GB (1x2GB) DDR3 PC3-12800C11 1600MHz Single Channel Module (TED32GM1600C1101) £14.99 (£29.98)
1 x LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA10B £13.99
1 x Arctic Silver 5 Thermal Compound (3.5g) £8.99
Total : £362.48 (includes shipping : £8.00).
Right, i put a post up a few weeks ago asking for specs on a mini itx build for a htpc.
the spec above are more or less the same as someone from here had said, just with a few tweeks.
So will this all fit into the case i'm buying? the PSU is my main concern, as the case specification states 140x150x86 and the PSU i have is 163x150x86. I'm guessing it'll be fine as the picture on ocuk shows the case with a 750w PSU which is surly bigger than my 300w.
Is there anything any of you guys would change? this is my first build and don't particularly know what's best for the 350 budget i've set. also, and most importantly, have i missed anything? haha.
thanks guys.
thanks guys.
