Finally decided! :D
4 Jan 2011
Manchester
Okay so after weeks of looking into things, today is the day I begin purchasing my new components, with the plan to be finished by payday next month.
I've decided on this to begin with:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £177.98
(£148.32) £177.98
Foxconn P67A-S Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £99.98
(£83.32) £99.98
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £43.99
(£36.66) £43.99
And over February I'm hoping to purchase the following:
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card £251.99
(£209.99) £251.99
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) £89.99
(£74.99) £89.99
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £64.99
(£54.16) £64.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.99
(£34.16) £40.99
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £35.74
(£29.78) £35.74
All to be housed in an already purchased Cooler Master Storm Sniper :D
Any comments on the build? Anything you'd change? Oh and any opinions on that cooler?
Thanks! :D
Edit: Oh and a big thanks that gave advice, especially Stulid! Greatly appreciated!
Was planning on going Sli later on this year. Only concern is the PSU. Will that be enough for 2x 560 Phantoms?
Cheers Stulid, you're always a great help and its really appreciated.
CMS
You should probably consider paying the £10 extra for retail version of the 2500K for the 2 years extra warranty...as the new CPU ain't as indestructable as older CPU like the Q6600 etc...
Yeah, i was seriously thinking about that. I don't want to spend this amount of money for it to go wrong 2 years down the line and end up having to pay for a new one.
If you're going SLI you ideally want 750W minimum (what I have with my 2x460s).
Also I couldn't find out but I have a suspicion the Foxconn doesn't support SLI - support of SLI is something which usually adds a premium.
