Finally Decided on everything!
20 Jun 2006
As usual i have been very indecisive when it comes to parts for my next new build.
In the end i have opted for the following:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail + Far Cry 2 Game
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Asus ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card £164.99
Be Quiet! Dark Power Pro 650W ATX2.2 Modular SLi Compliant Power Supply
Coolermaster Storm 'Scout' Gaming Case - (No PSU) £80.99
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) £72.99
OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK)
Thermalright Ultra-120 Extreme CPU Cooler (Socket LGA1366/LGA775)
Hopefully everything will arrive friday so i can get building over the weekend!
Thanks for all the input over the last few weeks!
Ill be honest, it was a choice between the antec 900-2 or the scout. in the end budget started getting tight so tried to shave a few quid off.
Bit of an update, put it all together and it posted first time!
Have got the OS installed, and although theres a few tweaks have now switched to cable management mode. As a result of that i decided to buy some more optical drives and rid myself of the dreaded IDE cables!.
Little bit concerned with the True though, it does like to twist a bit too much for my liking.
Will take a before picture later on and then show off the after once im done.
