Finally Decided
9 Dec 2006
@ManCave
after all this time deciding
Just Ordered 2x EVGA 2.5GB 570GTX Graphics Cards for 2560x1600
BF3 here i come......
Cant wait for it to come out now:o
Not a biggie but your going to lose a bit of your ram with those cards. Win7x64 HP supports upto 16gb including vram. If you do need all your ram you'll need win7 pro, enterprise or ultimate all of which support 192gb! Nice choice though :)
No he's not.
Running W7 Home premium here with 16GB.
No reduction in the amount of RAM available due to the graphics cards installed.
Download a cpu temp monitoring program like coretemp. Then, assuming you have a decent cooler on your processor, just go in to the BIOS and change the FSB. By increasing the number in the bios you'll be able to see what actual overclock it will give you. There's a lot more to it than this (for further overclocking), but to simply get an overclock without needing to do anything else, just try changing the FSB and leave everything else on auto.
If you need further help try this :
http://forums.overclockers.co.uk/showthread.php?t=17612922
What monitor you going to use as will need a upgrade to get those resolutions, also can i ask why you bought 2 570`s why not 1 580 card
Very nice! Wish I could afford two 570GTX's - instead I need 4 new tyres for my car :o ******!
