- 20 Mar 2007
I have an awkward pair of hose ports on my case:
https://www.silverstonetek.com/raven/products/index.php?model=RV02
They are at the rear bottom of the case. This eventually causes flexible tubing to collapse due to the bend radius being less than the tubing would like. So, I've gone for brass 1/4" to 15mm compression couplings and speedfit bends and tubing! I could have just replaced the tubing in the problem areas, but I'm fairly convinced replacing all of it will be much neater, the flexible hose just sags all over the place...
The parts should be turning up today/tomorrow, should be fun!
Anyone else done the same/similar?
Also, anyone using a central heating pump?
(It's quite ugly now!). Obviously the will be without a CHP
