- 30 Nov 2011
The only way ive seen it done is res pump pump but no reason you couldnt stick one in say before or after the rad
Do OCUK stock the dye drops?
As I can't see them (unless I'm just being my usual blind self) I just didn't think about dyes...
Will I need to add biocide/kill coil in if just using a DI+dye combination?
Yes
Edit: seen the dye on mayhems site, around £6 a bottle, I'll ask rich/5UB if they can get some in on monday while I compile the rest of my requests for them
LOL
Also Cleee, what is your opinion on tube ID sizing and compression fittings, is 7/16 ID tube with 1/2 fittings a better option than say 1/2 and 1/2 or 7/16 and 7/16?
Thanks again, you genuinely are a fountain of watercooling knowledge
Just (hopefully) picked up some black sparkle 7/16 bitspower compression fittings from the MM![]()
Its fine radiator wise I'm dead set on the 1080, I have the room, plus it will only require 4 x 180mm fans that will be the phobya g-silent 700rpm so near silence too.
And before the 180mm thing gets mentioned I know 180 x 4 = 720, rather than its native 120 x 9 = 1080, not quite sure how phobya have managed it either but it looks the part
iTeks build and cyanides for that matter are both lovely, its just less hassle for me having the radiator external, plus it gives the extra cooling potential.
